i am putting a 96 4.0 in my 91 .my question is if the fuel rail off my 91 is a direct swap to the 96. i want to keep the injectors in the 96 and just swap the fuel rail.
The '91 fuel rail will do fine and I suggest you also use the '91-'95 injectors since they're designed for OBD 1 to run at a fuel pressure of 39psi. The '96 fuel injectors need 49psi to atomize the fuel properly.
