alroosa
- Cincinnati
I am learning a lot, thanks for the help guys!!
Vacuum is there. Tested the pressure again and @ prime it jumps to 40 for a split second; then down to 32, @ start it jumps to 40 but back to 32 when it runs for the few seconds it does and dies. I did a leak down test and it was fine, the pressure only dropped 16 PSI, the failure range is above 20.
When the pump primes it only runs for a second and there is voltage @ the pump for that time, after it is started there is voltage there after the engine dies.
I did a volume test and I get about 1 cup for 10 seconds. Is that the normal amount, the haynes manual doesn't have specifics for a volume test.
Could this be caused by a flaky sensor such as CPS? or maybe the computer since the power antennae pulled the battery down?
Thanks!!
Thanks!!
