Wondering what needs to be spliced in or modified and if I can use + install an "bargain find" from the local boneyard a 12-volt 1990 XJ Bosch fuel pump into the gas tank of a 1984 that had a 2.8 liter V-6 I believe-I just need the extra boost doing starting with another larger engine modification upgrade down the line-I only have that "wonderful" Haynes manual for reference so at this point I am needing some input/advice/suggestions/etc-TIA
