hey guys will the an 89 Renix block work with an HO head? Obviously I will use everything from the head up. I've searched and heavent found a direct answer without me posting a new thread. Thanks atriot:
Yes. Since you're swapping the entire top end, you've taken care of the worst of the problem (but you'll still have to adapt the RENIX TPS to the HO throttle body - which has been covered here with pictures more than a few times.)
And you probably want the 7120 head, which was 91-95, unless you already have this 98 stuff. But the TB will be the same no matter which 91+ intake you have. 7120 is just usually said to be the best, and the intake that is on these engines would have the fuel rail which can easily be made to work with the Renix fuel lines. Somewhere on here, which I can't find, is a thread about making an earlier fuel rail w/ return line fit onto a newer intake.
But I know with 91-95 intake you can just swap the fuel injectors, adapt the TPS, hook up fuel lines and be done
