8Mud
- Central Germany
Why not try unplugging a couple of vacuum lines from the front vacuum tree and see what happens. See if it will run and stay running.
Mine runs (kind of) with the MAP electrical connector disconnected. It just runs really rich.
Or take your IAC out, gently and with feeling (better yet use your old IAC) push the piston in about 3/16 ". Reinstall it and and try a start.
What you are describing, sounds like your IAC is stuck shut and you need some air to get it going.
Actually you are supposed to compress (close) the piston down some when installing a new IAC. There was a warning about this way back when, if you don't, you can possibly bend the IAC piston rod. Most of the manufacturers, deliver them partialy closed/compressed, but who knows for sure.
