I'm trying to fix the A/C on my 89 4.0 5 speed XJ. It's bone stock and running great but A/C is not even raising idle when turned on. Any good starting points to check for why it is not working? I've checked the compressor clutch by jumping 12 volts and it works fine. I've by passed the low pressure switch briefly and that made no difference. I have a factory service manual and am good with electrical, I'm just not sure where to check next. (I tested the relay and it works, it's just not turning on.)
