88 with factory tow option
90xj06
Peabody, MA
My 88 came with I believe the class 1/2 tow package as it has a factory trailer light connector and nutstrips in the frame
It has a 5 pin flat connector but it's too big for any current adapters I could find. I'd rather not have to splice in a replacement. Has anyone run into this before?
Looks like nobody could help?
All I can suggest is to go to etrailer.com. If you don't see what they have on their website a quick phone call will get you in touch with someone who does trailers and lighting all day.
I have an 88 with factory tow. Class 1 hitch, LSD, Aux cooler, full size spare. Never towed anything. Does have the 5 wire connector.
How many pins on the trailer? A 4 pin flat trailer side should still fit on the 5 pin Jeep side. The "odd ball" is the ground. You'll have one pin empty (trailer brakes).
Check out:
https://www.etrailer.com/question-46983.html
Other wire you'll need to wire an adapter.
It would be easier to fix it once with a common receptacle!!!!!!!!!
Check out:
the flat 5 pin is just larger in size than the current 4 and 5 pin trailer connectors.
i may splice in a 7 pin connector as i have all the wires for it.
Hmm... I'll have to measure mine.
