Talyn
- Radford, Communistwealth of Virginia
Why is that mount so tall?
Wideband installed and 93 in the tank. those 32lb injectors were too big so I took them out.. I went to some ford 4 hole yellow injectors because I had them laying around and the stock ones were leaking at the body. I installed a vortech FMU with the 12:1 disk.
I drove it and the AFR under boost is decent. It stays in the mid 11s for the most part with a rare spike to 12.1. My boost guage will hit 5psi max. It feels like it gained some decent amount of power. I can spin one tire through my open diff well into 3rd gear. The Bypass valve is reacting instantaneous when I let off the throttle, like a BOV. It even sounds like one! I got back after my drive and already found a boost leak at the throttle body gasket so it still needs some tweaking. I want to try some ford 24lb blues so I can go down a disk or two on the FMU. (fuel gauge reading 70+psi at rail under boost.)
However Now that I have my wideband installed I notice the jeep is running too rich at idle and cruise. I think its a sensor or exhaust leak. Im only running 19 lb injectors so I should have a normal AFR when not in boost. The 32lb injectors may work once I get the rich idle problem fixed. Going to try and get it running right at idle and cruise first before I continue anymore with the supercharger side of things.
I have more pictures to upload and maybe a video.
In the meanwhile im gonna figure out what I want to do with the rear end. Ford 8.8 or another dana 35 with posi. Im split between a 3.55, 3.73, and 4.10 gear. I'm worried the 4.10 gear will make first gear useless. Well Im worried any shorter rear end gear will make first gear useless. Hell, it may already be useless and I should start in 2nd.
Also gonna work on lowering it a little just a little in the front and level out the rear.
Let me know what you think!
I have 4.56 on 32" tires in my MJ with the AW4 automatic around 270 horsepower. I wish I had 3.73 or 4.10. 4.10 would let me cruise around 65 MPH and still keep reasonable towing power. 3.73 would be the best for mine to cruise comfortably at 70 MPH and not guzzle gas.
