woody431
- Virden, IL
I have an 8 lug set up for a Dana 44 front axle. These parts came from a 76 F250.
The knuckles are both flattops, passenger side has been milled, drilled, and tapped for a high steerm arm. (I had a WFO arm on it). Also has new ball joints installed. Driver side knuckle will need ball joints and drilled and tapped to run full high steer. I had originally planned on crossover.
Brakes are the big two piston style. I bought these as new and loaded, so everything is new on them. Rotors are also new, but are rusted from not being used. As seen in pic. One caliper bracket needs the caliper alignment bolt drilled out and retapped(was broke off when I got it).
Hubs have been cleaned, new bearings, lockouts are original, but still work good, they are the big D60 size. Spindles have also been cleaned, bearing surfaces are good, new seals.
Im not sure if there is anything Im forgetting, but any questions please ask. Located in Virden, IL.. 30 minutes south of Springfield. About 1.5 hours from StL up I55. Im asking $400 obo. Email me at [email protected] or call (217)652-3918
