CleanInstall
- Allen, Texas
for those of you that have swapped an 8.8 in your xjs, have you found it necessary to use a slip yoke eliminator? I am just about finished with the build on my axle and it's about to go under my 94 with 4.5 inch rustys lift and 33's. so far it has been vibe free, but I worry about the pinion yoke length differences between the 35 and the 8.8. btw, I have incorporated the same pinion angle as my current setup with shims into the spring perch angle on the 8.8. thanks.
-mike
-mike
