TRAILREADYXJ
- Raleigh NC
My $.02
I am at about 6" with no SYE. I have replaced my D35 with a 8.25. The shaft for the D35 is a little longer than the 8.25. This put the slip yolk in the right spot for no vibes or binding (proper bumpstops a must). I also added a 1" T-case drop.
Every XJ is different, the earlier models are less likely to have vibes due to the type of slip yolk they use. Later models changed to an "exterior" slip yolk, if you have one of these, prepare for a SYE, may even need it at 3".
Also remember if you lift it and plan to add a SYE later, you will need to change your rear pinion angle. With a SYE the pinion should point directly at the DS (or slightly below to allow for axle wrap). With no SYE it needs to be parallel with the slip yolk.
