- MilkyWay Galaxy
mattbred,
I am not sure about part of what you said below. You said itdropped from 15 ohms to less than 1 ohm with the battery cable disconected, but which battery cable was disconnected? Was it only the possitive, or was when either battery cable was disconnected. Also did you have the ignition turned off?
What you might do is disconnect the negative battery cable, with the ignition key out (everthing off, and pull the hood light bulb for a minute, then check the negative battery post to the negative battery cable connector while disconnected to see if there is any voltage present. IF there is voltage pressent then something is still powered up on its own, and it will affect the ground ohm measurement when the negative cable is connected to the battery.
In which case you need to disconnect the positive cable to get an accurate negative battery post to engine/firewall ground reading. Then you might want to chase down what is still running (I do not have a hood light bulb, nor does anything else that I know of run when my hood is up and doors are open on mine (no courtesy light bulbs anywhere in my jeep, so most others might need to disconect that positive cable if they have dome and hood lights working, security systems, clocks, etc that run all the time!!!!!
Probably just a coincidence that mine are all off, disconected, not powered up so I did not need to disconnect the positive cable on mine.
