cherokeecrawler
- Atlanta, GA
Hey all, gonna be doing a 5 speed swap in the next few months and was wondering what all would be needed, what I need to gather, buy, etc.. Looked around a little bit but hard to find the info I need so I figured I'd just ask myself.
I have a 99 xj sport 4wd, and the swap will be coming from a 98 TJ. Motor and trans. Xj is my weekend warrior but still in pretty shape, so I'd like to make it a clean factory looking swap.
Now I assume all the main parts will bolt up(motor/trans) but not so sure about everything else? Pedal assembly, clutch booster, etc.
Also what would you recommend get replaced as far as seals and such. The TJ has about 140k and was well maintained but is from a built crawler and abused a little bit. I've driven it a fair amount, road and trail, and it shifts good 1-5, but does grind sometimes going into reverse. More than likely gonna replace the clutch face also.
Thank y'all in advance. :eeks1:
