tkm
- northern kentucky
Electronic Control Unit Transmision Control unit
I personaly did not use the switch and if I were todo it again I would not use the switch. it is an unnesasary PITA your 89 trans as long as it is an aw4 will bolt up and plug in and work well in your 92 as long as you change the speedometer speed sinsor it the tail shaft on the trans. 90 and earier were cable and 91 up were electronic.
as far as the tach gauge goes you would probably be better off selling the gauges you have in your 89 and buying some from the corect year. it could be done but it would not be worth the headeach.
