Jip
- South Carolina
Got a '96 Cherokee 4.0, auto, 4x4 with around 180k miles on it. I've only used the 4H on the TC, and I've only done it maybe 10 times since I got this Cherokee about 2 yrs ago.
I was going to consult the owners manual, but I don't have one. The Haynes manual hasn't told me what I want to know.
Here is my issue, I'll try to give a step-by-step here:
I put the trans in DRIVE.
Then I shift the TC lever down to 4H. Then I see a "part time" light illuminate on the right side of the dash.
I then try to shift the TC lever to 4L, but it won't go.
I put the trans in NEUTRAL.
Then I pull the TC lever into 4L, and it goes right in.
I apply the throttle put it just revs like its not even in gear.
Then I can put it in NEUTRAL, DRIVE, or PARK; then try to take the TC lever from 4L to 4H, and it just grinds, b/c now it won't come out of 4L without grrrriiiinnddding!
Finally, I shut down my Cherokee, and move the TC lever back to 2 wheel drive while the engine is OFF.
So, basically I've got 4H, and no 4L. I'm still unsure on how to adjust everything.
ANY help would be appreciated, thanks!
