Talyn
- Radford, Communistwealth of Virginia
Found this and thought I would pass it on. No relation to seller. http://www.ebay.com/itm/191476186773?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Flap wheel on a drill press, faster-how else?.... F&B, Painless, BBK, new TBs seem to be priced similar to $400+. I'll take a day to use a drill press & flap wheel to open TB and manifold dia. to 68mm.
If you open a stock throttle body to 68mm you will have a tin foil throttle body if anything is left at all. IIRC the outside diameter of the stock throttle body is around 66-68mm at the narrowest. All of the aftermarket throttle bodies of that size are entirely new components machined from solid billet.
