BarFlyFisherman
(4) OEM Mopar2003, 2004, 2005, 2006 Jeep Wrangler Wheels with 34x10.5-16 Super Swampers
Wheels: 16" x 8"
Bolt pattern = 5 x 4.5"/5X114.3
Center Bore Diameter: 71.5
Center Caps Included
Pictures appear in order.
This bolt pattern & center bore also fits Jeep TJ, LJ, Rubicon, Sport, XJ's. Check your vehicle for fitment - not responsible if they do not fit.
Wheels:
Wheels #1,2,3 have "rock rash" on the outside of the rim - (Street queen Jeeps call this: wife + curb)
All wheels are crack free, straight, not bent and hold air.
Shortened metal custom valve stems.
Tires:
Super Swampers
They are labeled TSL, but these are now called LTB's.
4 plies tread, 4 plies sidewall
LOAD Range: D 3,195 Pounds
Only 3,000 miles on the tires.
All tires have some side wall scuffing, as they were used for trailing running (no jumping).
All tires hold air.
Tire #3 has a small gouge out of the side wall (see close-up in image #4 following image of tire #3).
If you are concerned about sidewalls, you can install tubes.
New - Tires alone costs over $1,100!
Also listed on EBay (see item #140873963654 for pictures).
Tires are in Hollister, CA.
First $500 or consider trade for Dana 44/60 rear axle.
Wheels: 16" x 8"
Wheels:
Tires:
Super Swampers
All tires hold air.
