ZachMan said:Sounds like you need less lift. 35s on the RE 4.5" is perfect.
Yeah, a little less lift would be nice. What do you use for bump stops? Do you have any pictures you could post? I have the extended bump stops on the top and the supplied ones from RE (5.5") on the bottom, have trimmed a lot, use the bushwacker flares and still get into my front fenders at full flex.
I actually run wheel spacers right now on my 8" rims and want to get away from it (I have never had a problem with the wheel spacers running 4+ trails in Utah) because they are illegal in Utah.
On my old wrangler I did lose a bead on rocker knocker and flopped on my side with an 8" rim, but I think my air pressure was about 6 lbs. or so. The reason I am considering the 10" rims is that I have seen a few people running them on the trails and not noticed any problems....the wheel bearing/hub issue is something to be concerned about.......
Decisions!
