Rowdy CHEMJ
- Syracuse
Nice swap!I did mine with a 5.3L, the whole thing was difficult. If it wasn't everyone would have one. The hp/torque feels absolutely perfect in the XJ. The first ride around the block you will be wondering what took you so long to do it.
I agree!!
I installed a Chev. 350 in my '89 MJ. It's great! It is easy is reliable, has tons of power, and gets better mileage than the 4.0. I used Novak's bolt-in aluminum radiator with two 4.0 electric fans. Running 35" tires, it has never gone above 210 degrees.
Radiator - $560
Bolt-in motor mounts (Novak) - $200
Coated headers - $385
Adapter from 700R4 to t-case - $500
Engine - $250
Rebuilt 700R4 - $1000
Fans - $20
Tach converter (Dakota Digital) - $80
Lokar shifter in factory MJ console - $300
Total = $3300 (and this wasn't really cutting any corners)
If installing a 5.3 the only cost difference in the parts is the motor, and that can go either way. The Gen. III engines requires more wiring, but can still use factory gauges, etc.
There were no mods needed to the firewall, grill, hood, and I used all the factory gauges. It came together really nice and is now far more reliable than it was before.
My understanding is you can use the AW4. To control it, you simply need to retain the TCU under the dash.
