law.74
- Too far from Moab
YES I could. I also used engine vac. The t-case doesn't generate vac. it just switches engine vac. It is possible it is "restricted" I suppose.jeepcomj said:...law 7.4...I HAVE this done on my comanche, and NO you cannot shift at "moderate speeds" without grinding. my wheels spin at the same speed, and the only time i can shift is below 10mph. this is because my assembly is running off of engine vacuum. the engine produces more vacuum than the t-case, and so it wants to force the actuator over...whereas the t-case actually slowly pushes the actuator.
YMMV... moving on...
