That's true only for the '87-'90 258 crank (54mm snout). The '81-'86 version also has 4 counterweights but a longer snout (64mm).
Sounds like you have the right crank for the serpentine pulley Almeek69.
thanks for the info just wanted to make sure i get the right one. was woried it was a little short. I am building dr dyno's stroker with a hesco head. hoping to get arround 300 hp.
Sorry to disappoint you but you won't get 300hp from 4.6L. At a push you might reach 270-275 if you copy my combination but with a 9.5:1 CR. That's still a respectable output especially if you have 330lbft of torque. I ported my head pretty much to the max and I can't see Hesco's head being 10hp better with the same stock sized valves.
To get near 300hp you'll need a 4.8L displacement, longer duration cam, and a CR over 10:1.
