BrettM
- michifornia
there were a handful of times on Outer Limits in JV that I had everything bound up enough that I could push to max torque (2500ish) and not budge at all. With about 1260ft/lbs going into my t-case, and 3430 going to the chain, the chain began slipping with a wonderful, loud pop-pop-pop.Weasel said:I dunno about those torque numbers, I mean I know the math is right but the only time you are ever going to see that is if your tire is wedged under a rock, not turning and you give it all the power you can. And if thats the case I don't know of much that would hold up.
I had never experienced this on NorCal trails, but on JV type terrain it is fairly easy.
Surprisingly, nothing broke, not even the Spicer front shafts.
