2001 XJ for sale
Stormy
Portland, OR
I am the 3rd owner, previous owner had for 10 years/105k and added all the mods without an asterisk.
I've owned the Jeep for 8 months/5k miles and changed the diff fluid, transmission fluid, oil, battery, alternator, radiator, ball joints, etc. Awesome truck but I no longer use it and could use the money on other projects
The Good:
-32" Courser MXT Mastercraft tires w/ less than 5k on them*
-Warn VR8000 winch w/ steel cable*
-Bilstein 5100 Shocks front and rear
-Old Man Emu 2" Medium leaf springs
-ZJ V8 Front springs
-4.10 gears all around, professionally installed
-JCR Stage 1 Rear bumper
-ARB Front Bumper w/ Factor wrangler fogs
-Stealth Box subwoofer and amp
-Alpine/Polk Audio 6.5" speakers
-Pioneer Deck w/ proper wiring harness, no birds nest of wires
-HD Offroad Engineering front/mid stiffeners
-IronMan4X4Fab Xtreme trackbar w/ crossbrace
-IronMan4X4Fab Motor mounts (lifts .25" to clear trackbar brace)
-Upgraded grounds/main power cables
-SYE in 231 using a front driveshaft
-RA Designs- Raid II shifte controller w/ switches for TC and shifter enable (I never used these but was assured they worked)
-Durango Steering Box
-Upgraded ZJ 138 Amp alternator *replaced in May along with Autocraft Gold battery w/3 year warranty*
-28mm ZJ sway bar w/ quick disconnects
-ZJ front tie rod *replaced in Jan
-Adeco 7/8" rear sway bar
-Throttle body bored to 60mm
-ZJ rear disc brake conversion
-New front calipers, pads, refinished rotors*replaced in February
-New ball joints *replaced in February
-EBC brake pads
-Stainless Brake lines
-Trans cooler piped so radiator quickly warms fluid and external cooler maintains coolness.
-Brand new radiator *replaced july*
-New drivers side window control unit *replaced Jan
-Tight steering
Will include 50" Hi-lift jack, tree saver, snatch block, tow strap, D rings, extra gaskets (came with car) extra catalytic converter (came with car)
The Bad:
-Front speakers do not work (passenger cuts in and out. Need to solder wiring in door)
-Trunk lid does not have interior trim
-Exterior paint clear coat showing wear.
267 884-4588 with cash offers. Or old VW trades
