JMOliver
- North Carolina
I figured could help with this!
I have a 2001 Jeep Wrangler with 4.0 and 5 spd. Jeep has coil packs,
Ok here's what I need help figuring out, jeep will start up and idle and when it gets warmed up it will drop to appropriate rpms. At this point it has just a tad of a miss thats not even noticeable about, if you tap the gas it will almost die. Sometimes it does and is hard to start.
Beyond that here's what else it is doing, when driving in gears 1-3 it will buck badly when gas pedal is applied more than 1/4 - 1/2 throttle. I have noticed in gears 4-5 and reverse that this thing drives normal with no problems,
Any suggestions?
What I have done so far!
1. Checked fuel psi. (47psi)
2. Completely cleaned throttle body
3. New TPS sensor
4. Scanned with good computer - no codes
5. Changed oil - just because.
6. Sea foamed fuel tank
7. Tried MAP sensor off my 99 XJ
Thanks!
JMOliver
Any suggestions?
3. New TPS sensor
Thanks!
JMOliver
