Talyn
- Radford, Communistwealth of Virginia
No, you still fail to understand.
You really think that .5 lb.hr is going to make that much difference? I'm sure you also knew that it runs rich after 3000 RPM in WOT with the stock injectors right?
And I almost forgot. Nominated
87-90 DO NOT use these injectors as an upgrade. The plug is different. They are not used on those years. Also, what does your subject say? It says 2001. Why would I offer these to you if I didn't think they would work?[*]The 87-90 stock xj group uses 39 psi @ 18.6 lb\hr. That is why they use this upgrade.
Higher PSI = more lb/hr[*]He then states, "22# on the Jeep 49 psi rail."
[*]The 00-01 stock xj group uses 49 psi's at 22.5 lb\hr.
