DanDXJ
- Raleigh, NC
The factory fan started vibrating awful. I purchased a Dorman replacement from Advance Auto. First off it has fewer blades and required an adapter (supplied) to correctly attach the pig tale. All looked well until I noticed that when it comes on it blows the hot air out of the radiator. I thought it was suppose to suck in toward the engine. I could reverse the wires and it should rotate the opposite direction but the "cups" on the blades would be backwards. The description on the website does not describe the rotation. Sitting in the drivers seat it rotates CCW. The OEM fan has the blade "cups" going the opposite direction. Did Dorman build it this way or did they screw up?I'm going to jumper the OEM fan to confirm. And yes the engine runs hot even with the fan running. Any insight would be appreciated.
DanDxj
DanDxj
