***Updated List***
RE 5.5" Lift, drop brackets, new bushings, will come with the spare bushings i have. Upper and lower CA's are adjustable, includes shocks- $500
35" Goodyear MTr Kevlar, worn evenly, great tread left, on Soft 8 rims, brand new spare, balanced with airsoft beads, great ride for 35's! Tread measurements are as follows, 14-12-12-12/32nds, the new spare measures 21/32nds and still has the sticker on it-$850
First gen. Wilderness Roof rack, includes highlift mount, spare tire mount, rack for shovel/axe and the eyehooks on the front for the 4 spotlights, crossbar on rear drilled for 2 backup lights- $250
tan leather seat from older xj, really good shape, 2 front and full rear seat, patched tear on passenger seat, mounted on manual sliders- $125
OBA setup, includes 3gal tank, manifold, a/c compressor and all the lines, very well setup, the tank and manifold mount in the rear cargo area, air line and chuck for tires included, fills all 4 35's in a matter of minutes and will run a 1/2" snapon air gun to take off pinion nuts with ease!- $200
4 KC Daylighters, 2 backup lights, 100w on the daylighters, 55w on the reverse lights, decent shape, one of the daylighters needs a bulb. Includes plastic covers and KC soft covers- $125
HP D30, was a vac disconnect, convert to newer solid shaft, 456 gears, TruTrac, WJ knuckles/brakes, highsteer using JKS/WJ RHD, Go-fer-it inserts, Wheel bearings and ball joint great shape, same for rod ends, ujoints, pads and rotors, Has mounts for sway bar links welded on; comes with spare shafts- $800
8.25, ZJ disc swap, new bearings and seals, 456 w powertracks, raised shock mounts, comes with spare shafts, pads and rotors are in great shape, includes ruffstuff OS ubolts and HD spring top hats- $400
JKS trackbar, the home brew one, NEVER driven on, will be sanded and painted before sale; has rebuildable ball joints and comes with RE track bar bracket- $150
Home brew hand throttle -$50
60" Highlift jack, needs some lube but still good working order -$50
JCR Steel tail light buckets, LED lights and harnesses, thickly painted with MackBlack paints, GREAT shape!- $190
3 stock front driveshafts, 2 with rebuilt cardans, $35 each
231 TC with stock tailshaft- $100
Tan center console, comes with painted black bracket on pass. side for GPS mount- $30
Tan lighted visors- $30
ZJ shift knob- $10
HD battery shutoff switch, Painted bracket, mounts right behind battery, all cables included VERY HEAVY DUTY, 230amp switch- $80
Black rear doors, power windows locks, great shape, with the exception of a dent in the passenger rear door, tinted rear glass, all options work, complete door assy's- $50/door
rear hatch, black, small dent on drivers side, inside platic panel needs a couple tree pins to hold in place- $65
2" Poly Budget spring spacers- $20
OEM steering box, good shape, no leaks- $50
Durango HD steering box, good shape no leaks- $65
Inline 6 coil pack, good shape- $60
6 Spidertrax 1.25" wheel spacers, $75 per 2 spacer
Trailhead Tire Deflator set, comes with 4 deflators, allen key, PSI gauge, manual and quick reference sheet for tire psi's, 5-20psi range adjustability, used 3 times. $50
Cherokee shell, very little rust, some dents and dings and scratches, rockers and rear quarters dent up, in sheet metal, "Frame-rails" are in great shape, comes with AW4 trans attached!- $200
Most interior panels, mirrors, interior lights, engine, tranny, outside front end lights, and anything in the engine bay available, pm for pricing...
