1998 Cherokee Sport
4.0 Straight 6 (runs good around 130K)
throtle body spacer
Fiberglass hood with 2" functional scoop
Aw-4 auto (shifts smooth)
231-J transfercase (also shifts into and out of all gears fine)
terra 2low
SYE
4.5 inch lift (unknown maker)
short arms with drop brackets
32"x12.5"x15" good year MT's (40% tread or less no spare)
15" Mickey Thompson Classic II Alloy Wheel
8.8 rear axle with a lockrite
disk brake conversion
dana 30 front axle
Mile marker hub conversion kit
ott Steering Kit from rocky-road.com
4.56's
Rugged Ridge HD Steering Box Brace
custom driveshafts front and rear
rear quarter side guards (just the lower section with the body lines)
Rocker guards (unknown maker)
Tomken Engine & Transmisison Skid Plate
pre-96 gas tank skid modded to fit
Bushwacker flares
Olympic 4x4 Products Rock Winch Bumper
warn M8000-CE winch with incab control
Olympic 4X4 Rear Rock Bumper with tire carrier
Riddler Manufacturing Differential Cover (front and rear)
heavy duty rear brake light carrier (made with 1/8" plate steel)
full internal cage ( i know it was a local guy who made it and its an early version of his current work)
Cobra 29 LTD Classic CB with a 48" firestick antenna
roof rack (unknown maker)
rear cargo rack made from wood but it lets you have a little more storage for camping and wheeling
The bad: front bearings need greased and repacked, got its first body crease the other day in the rear behind the window from the unibody flex, needs a new steering setup this system is crap but works, needs new gear oil front and rear.
Well built jeep cant offer reciepts for the build since i bought it pre-built, but it has been to moab twice and ran spring creek here in CO. Did great both places with no major breakage. pm's, email, texts (verizon customers only) and calls welcome. leave a message if I dont answer as my work schedule is very random, i'll call you back ASAP.
seven 2zero-two 7five-two 1nine3
http://denver.craigslist.org/cto/2675593295.html
throtle body spacer
terra 2low
SYE
dana 30 front axle
4.56's
Bushwacker flares
