- NE Indiana
1998 5.9 ZJ with 236k.
When you are driving in the summer the a/c is cold while you are driving. While you are stopped, it gets hot and there's a slight smell of burning oil.
In the winter, when you are driving the heat works great. While you are stopped, it gets cold.
I played with the Freon in it. I thought maybe it was low. I tried to add a can and it appeared to be way over filled. It was maxed out on the gauge. I then put just the gauge on it without trying to put a can of Freon in. I watched the gauge as the Jeep idled with a/c at max. It would show maxed out over filled until the fan kicked on. When the fan kicked on it would go back in the normal range. Once the fan kicked on it would slowly build pressure until it was maxing the gauge out. The compressor would kick on and off, once the fan kicked on again it would go back into a normal range and repeat. The a/c was warm to just barely cool while doing this.
I have no clue if the odd operating of the a/c is related to the heater being cold at stops or not.
The 5.9 from the factory has an electric fan and doesn't use a mechanical fan at all. The jeep appears to be cooling normally.
mac 'not sure where to start' gyvr
