Dave41079
- Nashville, TN
I've searched and read and then some. On the 1996's everything I've found says to ground pin A12(dark blue/orange) into the PCM to activate the high idle. I tried this and nothing happened. I know I'm not alone here because in this thread http://www.naxja.org/forum/showthread.php?t=79549&highlight=extended+idle+ecu+pin CommandoXJ96 was having this same problem. I have not yet found a solution and was wondering if anyone knew what I could do to make it work. I've thought about tapping into the cruise module and playing with that to get it to work, but it's just an idea being tossed around right now and nothing I've actually put much thought into. I'd rather go with the simple version of being able to ground a pin to the PCM.
