1995 Cherokee Lifted
xjmatt
Lakewood, CO
I'm selling it because I just don't drive it much anymore. For the most part it's been doing an awesome job of holding down the concrete inside my garage for the past 4 years. I enjoyed building it more than wheeling it and have since moved onto other projects. I did all the work myself other than the axle re-gearing and if I removed a bolt I replaced it with grade 8 and a lot of anti-seize. At this point there isn't much on it that I have not replaced.
Does have a little body damage from sliding into a tree on a slippery Jenny Creek run and a spot on the drivers side door where the paint chipped from a similar. All in all it's solid but does have all the 'characteristics' you'd expect from an XJ with 177K miles. Price $4,500
To contact please PM or you can email me at [email protected] .
1995 Jeep Cherokee
Exterior: Red
Interior: Gray Cloth
Engine: 4.0L
177k Miles on body 70K on rebuilt engine
very minor rear main drip (surprise!)
Lift
5" Rubicon Express Lift
RE super ride Adjustable UCA's
Rusty's adjustable lower LCA's
Rough Country Drop Brackets
1.5" Rubicon Express shackle
JKS Adjustable Coil Over spacers
4" RE Coil springs
4" RE full leaf packs
Braided stainless brake lines front and rear
RE Adjustable drag link and HD bracket
JKS Quicker disconnects
Axles
Dana 30 front with 297x shafts
Chrysler 8.25 rear with 29 spline shafts
Axles regeared 4.10
Grand Cherokee rear disk brake conversion
Driveline
AX-15 manual transmission
NP-231 Transfer case
JB Conversions SYE
High angle driveline double cardan drive shaft
Everything else
ARB Bull bar with upgraded THOR mounting plates to reinforce front end and steering box
Superwinch EP9 (not wired in yet and doesn't have a single pull on it)
Tomkin rear bumper with swing out tire carrier
c-ROK inner stering brace
3-Core Modine radiator
1 TON Dodge tie rod ends
Custom DOM tie rod
Currie Enterprises Drag Link
AR767 steel wheels with 4.5" Back spacing
33x12.5 R15 Pro-Comp all terrain tires with 45% tread left
33x10.5 R15 BFG MT Spare on a AR767 with 4.5" BS
Hella 500 driving lights
K&N Cone filter and Rusty's bracket
OME steering damper
Brown dog motor mounts
Other new-ish parts
Battery (autozone gold)
Water pump
Thermostat
Upper and lower Radiator hose (lower has the spring inside)
starter
front axle U-Joints
Napa Gold Ball Joints (lifetime warranty)
Timkin front Hub bearing units
brake pads
distributor
plug wires
Various spare parts, the more I look through the garage the more I'll find
Maintenance
Engine: Mobile 1 10W30 fully synthetic and Mobile 1 filter since Mile 1
Diffs: Mobile 1 75w90 Fully synthetic
Transmission: Redline MT Fully Synthetic
Transfer Case: Mobile 1 ATF fully synthetic
Champion Truck plugs
