avocado
- Portland Oregon
Morning everyone.... Just wanted to see if anyone has any new ideas on the issues I am continueing to have... So here is what I have changed out: TPS, CPS, o2 sensor, IAC, ignition coil, alternator, battery, fuel pump and filter, CTS, fuel hoses and radiator hose. So now it starts but won't idle. I have to keep pumping the gas to keep it running otherwise it will die?? I can't get it to run long enough to get it to a parts store to read the code. I do know that the catalytic converter needs to be replaced but I am thinking idle issue is un related?? Is ignition switch a possibility? Anything helps,
thanks, Mike(avocado)
