33jeep
- North Carolina
1990 Jeep Cherokee 4door with 241,000 on the clock.
Manual door locks and windows.
4.7 Stroker built 4 years ago. Speed-o-motive kit .030 over in 90 block with 92 HO head ported and polished. Comp Cam with Comp springs and Mopar Performance spring retainers. K and N filter with 60 millimeter throttle body and 24 pound Ford Motorsports injectors. Borla stainless header into magnaflow high flow cat and flowmaster delta 40, 2.5 inch all the way back.
AW4 was rebuilt when engine was built and it has a NP231 with an Advance Adapters HD Short shaft kit protected by a TnT Customs belly pan.
Suspension is Rusty’s Offroad 6.5 inch front with adjustable control arms and trac bar. Rear is 4.5 Rough Country leaf spring with a 1.5 shackle. Body is trimmed and suspension is bumpstopped to prevent tire rubbage.
Tires are 35x13.50x15 BF Goodrich Krawlers with 99% tread mounted on 15x8 Mickey Thompson Classic 2s. They have been to uwharrie a few times and to Harlan, Ky once. Less than 500 miles on the road.
Axles are the stock Dana 30 and 35 with Genuine Gear Quick Locks and 4.10 gears. Front has Milemarker hub conversion with 760 u joints and 2 spare Warn hubs. Both Axles have Ruff Stuff Specialties covers. Rear axle has the shock mounts moved even with the bottom of the axle tube.
Custom front winch bumper with Ramsey pro plus 9500 winch
Price $4000 OBO!!!
Located in Newport.
Price $4000 OBO!!!
Located in Newport.
