semperfi1371
Okay at a loss. Started fine this morning but had a slight miss which was new but nothing terrible. Took kid to school, went for coffee started again got home killed it checked plug wires and restarted...all good. Went in & futzed around for the day, 6 hours later wont start! WTF? Has spark at the coil and the plugs, 30+ psi at the rail while cranking, coincidentally the psi will drop back to zero as soon as key is released, but that is another day as I don't think its the problem here, checked cap & rotor both are new & good, checked all plug wire connections, etc. Nada! Sprayed starting fluid in TB, nothing, not even a rumble! Anyone have a clue???
Recent work done: check valve in fuel line (100+ miles back), new CPS, new cap, rotor, wires & E-3 plugs, newer fuel filter (within 5k), injector swap w/ new filters & O-rings (300+ miles ago), new pressure regulator, new starter solenoid, new negative battery wiring, new vacuum harness.
I'm stumped, but I need this thing to run! Just had knee surgery,Ive got therapy and Dr., plus I'm a single dad & it's all I got to get the kids to school! ugh..
Any and all help is readily appreciated!
1990, 4.0, auto, 375k
