Well that did it i retarded the distributor a tooth and now it runs just fine. So my when i timed the Cam and Crank i must of messed up tho i double triple and quadruple checked it cause i didn't want to screw it up, i still must of some how.
The resistance in my sensor grounds was some corrosion on my negative battery cable. I didnt get any cables when i got the truck so i stole some off a junkyard 90 something XJ and cleaned them up but inside the hole that the bolt goes thru there was alot of that white sulfur powder, I scrapped it out and now i have only 1.6 ohms of resistance at the MAP, TPS and O2 sensors.
Since i more than likely screwed up the timing chain is there any worry of hitting a valve at high rpms if its retarded a tooth on the cam? Im guessing that power and MPGs will suffer slightly but my worry now is destroying a valve and the head.
