Twisted_Dakota
- Ft. Worth, TX
1988 XJ Laredo
250,000 miles
Red
4dr
Automatic
Bad:
4x4 doesn't work (front ring gear is toast)
Over heats sitting in parking lot (have new hoses and Radiator)
There is some body damage.
What has been replaced:
CPS
Fuel Pressure regulator
Fuel Filter
Fuel Pump
Starter Relay
All Ground Wires
Battery
Battery Cables
Distributor Cap & Rotor
Spark Plug Wires
Spark Plugs
ECU/ ECM
When replacing the fuel pump I relocated the tank into the back of the jeep, cutting a whole in the rear of the jeep. There is NO back seat. No carpet from the rear of the front seats and back. No RUST.
This was going to be my project jeep so I would quit abusing my truck but school has to come first and I am running low on funds, so If you are interested send me a pm.
Thanks,
Evan.
250,000 miles
Red
4dr
Automatic
Bad:
CPS
Fuel Filter
Fuel Pump
Starter Relay
All Ground Wires
Battery
Battery Cables
Spark Plug Wires
Spark Plugs
ECU/ ECM
Thanks,
Evan.
