The engine is a Chevy junker and jumped time.
Okay, I haven't been able to get around to testing the things I need too due to midterms, but I can answer some of your guys' questions.
The fuel pump is inside the gas tank.
I'm not sure if my jeep has an IAT or not.
Idle Stepper Motor (Or Idle Speed Actuator) is explained here: http://www.4wdmechanix.com/Tuning-and-Troubleshooting-the-2.5L-Jeep-TBI-Four?r=1 I Think it serves the same purpose as the IAC.
Jeep Driver, I never set the fuel pressure after I removed the TB, didn't realize I had to. My WOT switch looks like it does in the previous link, it is mounted of the throttle bracket, I haven't messed with it.
Yeah, pretty much everything you need to know about my particular Jeep is on that link, including the stuff about the different FPR. It has a picture of it but doesn't mention it; if you ctrl-f 'oe-' the picture above is it.
Not sure what specific Renix parts they used, but I am 100% sure i have a TPS, as I have changed it out.
I'm not sure if my jeep has an IAT or not. Yes you have one, it is also called an MAT, see the link, info and picture for the MAT.
That is correct! No IAC, but an earlier version of it, a Idle Stepper Motor (Or Idle Speed Actuator. )
From the linked site: If there is a pressure regulator problem, the pressure regulator fits within the bowl beneath the fuel inlet. When servicing the pressure regulator, you check pressure at the test port. A running TBI engine will have 14-15 psi.Note—Excessively high pressure readings indicate a possible pinched fuel return line. Pressure regulator adjustments are usually minute and only to correct minor changes in the regulator and system over time. When there is not enough pressure, even after attempts to increase pressure at the regulator’s adjuster, there is either a restricted fuel supply system (pinched line, plugged filter) or a low output electric fuel pump in the fuel tank.
So the fuel pump and FPR are different.
No, it's not a Chevy, it's AMC.
86 2.5 tbi is renix. First year.
EcoMike,
I can't seem to figure out how to test the regulator. I see a little port on the side, do I need some sort of tool to stick in there and test it?
Yeah, I think it's adjusted by taking it out and using a flat tip to 'tighten' the seal or 'loosen'' it.
The one with the broken wire is the temp sensor to the ECM, TX28 is the part number.
http://www.4wdmechanix.com/Tuning-and-Troubleshooting-the-2.5L-Jeep-TBI-Four?r=1 seems to agree with JeepDriver - that the broken one is the CTS and the one on of the intake manifold is the MAT.
So, here is the info on the ohms of the sensors, and a video showcasing the sensors I didn’t know what they were but tested anyway. Watch the video first – I found a sensor that a connection broke out! https://youtu.be/qnPesBBGeiI
MAT - .9
WOT - .1
MAP – 0
CPS – 0
Sensor with broken connection - .9
Sensor that goes into the exhaust manifold and is good – 0
TPS- .1
