cherokeedriver420
- Sumner,Washington
you can put the pontiac motor in it with the 700r4 good combo but you'll probably have drive line work to do
cherokeedriver420 said:mine will run with the 4.0l all day and most of the time come out on top.
cherokeedriver420 said:if you want good power out of it bore it dont listen to these guys i drove mine on a rebuild hardcore for five years and just rebuilt it again fist time was 30 over and now 40 decent gas milage, and good power for what it is. mine will run with the 4.0l all day and most of the time come out on top. and yes its the wrist pin mine did the same thing but ive also seen it through more miles than any 4.0l . the clicking noise while turning it over is the P.O.S. chrysler starter relay you can get a ford solinoid and wire it in its a little tricky but you never have that problem again. If you need any more info you can PM me mine is an 86 and ive had it for a long time. Wouldnt trade it for anything.
techshooter02 said:The jeep We bought it for $50.00 plus the $17.00 for the carb rebuild kit.
The rig is in ok shape, would make a good trail rig. The body is pretty straight for the most part. paint clear coat is coming off.
I'm not sure what to do to it now, maybe just part it out.
techshooter02 said:I have always put some transmission oil in v8 motors to help with lifter tap and to help clean out some of the gunk in the motor, and never had an issue with it creating a problem in the motor. I'm pretty sure it had the wrist pin tap before I did that, that is probly why I got it for so cheep. and they said that it was an charging problem. It charges just fine. but heck it has a new radiator in it and new master cylender and new rear cylenders new drums and new shoes. oh and a new five gallon gas can in the rear.
I already have a 4.0L 88 cherokee I drive daily but we couldn't pass up the 50.00 for it plus the new parts.
I'll have to check the gear ratio in it to see what it is.
techshooter02 said:I thought I read someplace in this post, correct me if i'm wrong,
Would a 360 amc motor bolt up to this auto transmission in this 85 v6??? just a thought.
