it was time for a ac recharge so id thought id judt do the 134 conversion. i end up having to use all three cans. now there is NO cold air blowing. any thoughts on this? TIA scot
what did you use for the conversion? i have an 87 as well. i have no charge on mine. its time to do something about it because its getting way to hot. thanks
i hope you at least removed the r-12 and pulled a vacumn on the system before...
but right off hand it sounds like the pressure switch is bad or you have a restriction...and if you don't know what these are or how to check them...seek professional help......or at least a shadetree.
