- San Diego
1999XJ
I am trying to modify the headlight wiring in my junk so that the highbeams and lowbeams can be on at the same time.
I am running a set of Hella 500s with 100w bulbs in them for headlights. they are currently running on a relay triggered by the OEM headlight switch.
I have a set of LED pods wired to a relay triggered by the OEM high beam circuit.
the OEM switch is setup so that when you trigger the highbeams, it shuts the low beams off. understandable since the OEM configuration has both filaments in the same bulb.
how do I do this? I am the dumb and I can't seem to make it work.
