01 w/ Procomp 3" lift = vibrations
1. (Pic 2) Have Chattanooga DL replace that u-joint with a CV joint.
2. Add a 2* steel shim to the leaf packs to get your angle correct.
3. Enjoy.
I will be over in about 30 minutes with your parts so you can look at mine while I am there.
First,this pic looks bad(as in the front yoke looks pulled to far out and maybe even drooping),you definately need to do something(as in a SYE kit whether it be a H-n-T or HD unit).With your current set-up,driveshaft angle doesn't count,only pinion angle and transfer case output shaft angle.
My pinion angle is -5. Just going from my Mustang days I'd think you'd want the pinion angle closer to -2 for the least amount of vibrations. Would a 2-3* shim help me in this situation. I'll have to put off the SYE for a month or so.
The yoke is not coming off, too far out or drooping. LOL.
YEAH right!!!Coming from someone that wants him to add a cv joint to a stock shaft(I call ghetto!).
Its probably the T-case drop putting the tailshaft at more of an angle it doesn't seem to be drooping either. My slipyoke is just as far out as that one and all i have is an AAL in the back
So you are telling me that a 3" lift automatically calls forxa longer shaft? If you thought about the geometry of a tc drop, you would actually be pushing the yoke inward. Youre a magazine wheeler lol. I've run a stock shaft with a cv on 7.5" re longarms for a loooooong time and i wheel harder than you think. Dont be so narrow minded. Oh yeah. His tailshaft and yoke look identical to mine lol.
