Trailbst
- Westerly, RI
They are 315/75/16 Goodyear MT/Rs I got a great deal on them. Less than a thousand miles.
Will eventually have to get a little more lift.
Erik
Silverstreak01 said:so what size is that.....
Trailbst said:They are 315/75/16 Goodyear MT/Rs I got a great deal on them. Less than a thousand miles.
nhrocker said:Looks great!
You could get away with just relocating your flares. I liked the look of the stock flares, so I used a spare set of front flares in the back since they're larger than the stock back flares. Just swapped sides and split them so I could mount the front of them on the doors. Since I've got the same flares on both ends the wheel wells finally look even.
I hadn't seen anyone else do it either, so I figured I'd give it a try. I had a spare set sitting here anyway. They fit great IMO.Trailbst said:They got moved a little, not much though, so they still look stock.
Eventually, I'd like to do TJ flares. Your idea is unique though, hadn't heard of anyone doing that.
Erik
I would like to see some pictures of your rears. I'm running 38s and my fenders are cut. I dont like the TJ, or Bushwacker look. Before I saw your post I was reluctant, but willing to try using Rustys Rear flare. Cutting it, and mounting it on the rear of the door and fender. I think your :idea: is better. Thanks in advance. Russnhrocker said:Looks great!
