stumpXJ
- Atlanta, Georgia
I am waiting patiently for my Tom Woods rear shaft to get here after installing the Clayton 6.5" LA suspension lift and SYE, so I decided to build my tube bumper this weekend since I haven't been able to drive my jeep in about 3 weeks due to the suspension install.
I am a big fan of tube bumpers, partially because I personally think they look better, and because they are generally lighter. I also like my stingers. I had one on my old Tacoma, so I decided to put one on my XJ also. No, I have never used a stinger for its intended purpose, and I hope I never have to, that being said, I still like the way they look. I realize that not everyone likes tube bumpers, thats fine, beacuse I dont like plate bumpers. To each his own. And yes, I tied into the steering box bolts, and added a few more on the passenger side frame rails. 10 bolts in total for the mounting duties.
Now that that's out of the way, on to the pictures...
I decided my old XR8 winch needed a re-vamp, so I replaced all of the rusted bolts with stainless, cleaned and re-greased the inside, and painted the cross bars and engage/dis-engage handle. I also bought from Viking Winch Line 100 feet of new Amsteel Blue, red synthetic winch line to replace my old skin shredding, kinked up steel cable. And replaced the roller fairlead with a aluminum hawse from Viking.
While I was at it, I got a wireless winch controller from Milemarker, and installed that also.
Here, you can see where I mounted it on my steering column. Just flip the switch, and its an instant wireless system!
I am going to leave the outer/corner tubes open for now, as I may tie into my sliders eventually and make tube fenders. I used 1 3/4 HREW for the tube, 1/4" for the mounts, and 3/8 plate for the front/face plate. The winch plate area is also 1/4"
Finished the bumper off with a set of Hella 700FF's, that have been converted to HID. The lights on top are two Hella 4000 pencil beams (inner two) and Hella 4000 Euro Driving Beam (outer two), all converted to HID. Yep. They are bright. :sunshine:
I may eventually add some bracing on the stinger tubes just incase I ever do have to use it while wheeling, because although it is pretty strong as it is, it probably would'nt hold up (or hold me up) in a front roll over.
Let me know what you think. ~James
