kristuphir
- Lake Elizabeth, CA
I've searched and found a lot of folks with the "no crank, no start" symptoms my '87 4.0 is exhibiting, but I have an additional wrench to throw in.
I was waiting in line to get a smog test, just idling there. The idle suddenly dropped a little bit and stumbled, went back to normal, stumbled again, and then the motor died. Tried to restart it just to see what would happen, and got nothing - no click, no crank, and obviously no start. Had it towed 25 miles home (thanks, AAA Premier) where it continues to exhibit the same symptoms.
There's good power coming out of the battery at rest and the voltmeter had been reading normally in the 25 mile drive prior to the event. I get full power to the accessories when I turn the key as far as I can tell - the buzzers, fans, instruments and stuff all work as they should. There was plenty of fuel in the tank so I didn't run out of gas, but that would be moot anyway as the starter won't spin. I would suspect a bum starter, relay, neutral safety switch, etc. except that the XJ died mid-idle - this didn't just happen one day when I tried to start it.
Did I lose a sensor someplace, or is the ECU troubled, or am I making this more complicated than it is? Suggestions? TIA.
