solditforajeep
- Marquette, MI
98, 123,000, Runs pretty good slight knocking clicking whatever you want to call it when cold, Front and rear main seals show a drop of oil under them but none falls to the ground ever, Right now sitting in class noticed a coolant leak waiting to get out and check it out asap tonight, but besides that I have owned it one year, used pennzoil 5w30 had a friend working there so never did it myslelf. Now I am at a body shop with access to a lift so Im going to start doing it. I get a discout from Amsoil, thought about switching to their 10w30. However, Im scared of the main seals leaking worse and really dont want to change them soon, well or ever but that wont happen.
Sooo, what do ya'll recommend here, I dont wheel often, mostly tow a jetski in the summer, winter temps here range from -10 to 30, usually 20ish. Summer Highs in the 70 80's.
Should I do the switch now and see what happens, Stick with a 5 dub 30, switch to 10 dub, or one of those in a high mileage and what brands?? thanks
