2000bluexj
- Mass
well, went to the local pnp and got a rear 8 inch from a 4 runner. width measured 58.5. picked it up for 50 bucks because no 3rd member. they pull the 3rds as soon as they come in, and not wanting to spend 600 on a 96 up, i bought it. i did measure, its gunna be tight but it may work. it is set up for coil, but i will cut all the brackets off and set up fo leafs. also going to do a rear disk conversion using rodeo 44 disks. this will give a stock rear brake setup with 6x5.5 bp as well as a parking brake. pictures to come.
