| OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
97+ Power Window Problem, Any Help?
Not a realy big deal but I was just thinking about it. I dealt with no front windows on my 91 for years so this is nothing compared to that. I have a 99 Classic with power windows. Every now and then (50% of the time actually) the passenger switch doesn't work. I can always put the window up and down from the driver's switch so I know it isn't the motor or power conection to the motor, it is the switch.
So is this common? If so is there an easy fix? I'm planing on pulling the door panel off to replace the speakers soon, so I'll likely take a look and clean any contacts points. Thanks Last edited by 88JeepXJ; 08-11-2006 at 09:14. |
#2
Re: 97+ Power Window Problem, Any Help?
So the lockout button is the common problem?
#4
So it would seem. When ChryCo went to the cheap-a$$ plastic housing they stuffed it with equally crappy switches, the worst of which is the lockout button. You'll also find that the auto-down function is fairly prone to fail as well as the window regulator.
Dave Last edited by CantonXJ; 08-11-2006 at 09:32. |
#5
I got kinda the same thing.
I'm wondering if my problem could be the lockout switch. 97, LF and RR window work fine, RF and LR windows will only work about half the time. turning the key on and off and slamming the door have gotten them to work in the past, but they seem to only work when they want to. |
#6
Wow, I thought I was the only one with that problem, glad to hear I am not alone and it is a common problem, and even better to see how to fix it. Thanks
#7
I have the same problem with my 97XJ.
ONLY the passenger side window has the intermittent problem. I can ALWAYS operate from drivers door, but passenger sometimes can't operate window. I notice that the light on the passenger window button is off at night. That must indicate something. Also, my CB is connected to a yellow wire in the fuseblock area. When the window doesn't work, my CB doesn't work either. 100% of the time- they both either work or they both don't work. Any ideas?? Thanks, Jeff-97XJ |
#8
#9
This sounds like a problem I've read about elsewhere. It seems that another possible failure point is due to corrosion under the factory carpeting that gets to the wires that run there. The only way to know for sure is to pull the rugs up and have a look. Dave |
#10
Here are the pics of what I did. After doing this I no longer can use the lock-out button. So if you have kids you may not want to do this.
#11
Also check within the bundle as it passes through the driver door into the body. Lot's of years of flexing can cause wires to break.
#12
I seem to accidently hit the window lockout button often , sometimes one hit is enough to unlock windows when i finally notice, sometimes I have to hit it a hundred times. But that's not my main problem. I think I have a problem with the regulator. When it goes all the way up or down it makes a loud grinding. However a jammed regulator in an older car I had acted differently, so I wanted to double check. |
#13
Go ahead and plan on spending about $130 to get one from the dealer...they had plenty of them in stock when I had to get mine.
-Timbo -99 Sport, RE 3.5" Super Ride, JCR Stage 2 Front, 31" BFG AT's, SYE and a lot more nifty stuff Quote:
#14
Not sure if they have it for the XJ's but I put a regulator in my friends ZJ. Believe it or not Murray's auto parts had it (made by Dorman -- the HELP! people) about $55 or so, IIRC. Consists of the motor + regulator assy. Certainly worth a call.......
#15
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| power window problem | exgreenjeep | OEM Tech Discussion | 2 | 11-13-2005 19:48 |
| Power Window Problem | TroyAndEddie | OEM Tech Discussion | 2 | 03-02-2005 07:30 |
| Power Window Problem | IdeaMan | OEM Tech Discussion | 3 | 01-08-2005 12:48 |
| Power window problem | RacerXJ | OEM Tech Discussion | 3 | 08-04-2004 10:16 |
| another power window problem | cbremer | OEM Tech Discussion | 1 | 07-11-2003 15:09 |
