SCW
- SLC (yuck) UT
It's been near or over 100 degrees here for two weeks now, and I just can't seem to keep my Jeep cool, especially when towing my little trailer which only weighs about 1500# loaded. I usually do OK in town, traffic gets bad and towing over mountain passes is a joke at 100F, so here is what I have done.
At first I tried a 3-row radiator that I picked up used locally for $40, I figured if it solved my problems I was ahead that much money, but it didn't work. Next step was a new 2-row radiator and new water pump. Still won't stay cool very well in traffic if it's over 95F outside-
Here is my latest work. First step was to get the "right" heater core, after searching around quite a bit I decided on one for a mid-90's Ford Explorer, it's 2" thick, 6" wide and 7 1/2" long, and new from NAPA was $25. My first choice was actually the rear core from a mid-90's Tahoe as it is longer and only an inch thick, but the price was double.
First step was to mark the hood for the hole- I wanted to mount the core in the hood with a fan below it that would be temp controlled. I marked the hole with enough room around the edges to allow room for some nice padded weather stripping that would keep the vibrations from wearing on the core. Dimensions of the finished hole would be 6 1/4" x 7 3/4", but more than that I also cut inside of that dimension by 1/2 to leave material to fold back to provide rigidity. It works well, the panel is more rigid than the uncut side.
Marked the hole, then taped it off-
Made sure to protect the underside from sparks, not too much of an issue because the factory insulation was still on, but just to be safe-
I used an angle grinder with a cut-off disk-
After cutting the inside, I drilled hole tight to the corners-
Which allowed me a place to grind to without getting carried away-
Built some mounting brakets out of sheet metal and used plenty of weather stripping to avoid wear on the core-
This is what it looks like mounted from the inside-
Next step is to install a 10" fan (1250cfm) under the core and run it on a thermostat- Fan shipped two days ago, should be here early next week.
http://cgi.ebay.com/ebaymotors/ws/e...m=260010636896&ih=016&sspagename=STRK:MEWN:IT
After that I'll be installing hood scoops on both sides, but with the scoop turned backwards so that the fan will blow the warm air towards the windshield. On the drivers side I'll just cut a small area for venting and place a twin scoop on that side. Here are the scoops I'm using, they will also be on next week, but not painted.
http://cgi.ebay.com/ebaymotors/ws/e...m=290012085475&ih=019&sspagename=STRK:MEWN:IT
As of right now I can't do much else, I'm waiting for the fan and scoops, but I did get some (hopefully) good cement to fasten the scoops to the hood, and for now I'll run the fan on the same adjustable thermostat that runs my electric fan.
After this I shouldn't have trouble cruising over mountain passes with my trailer, but I'm headed to the Utah-AridZona border next weekend with my trailer, so that will be the acid test.
