Old April 21st, 2007, 18:31
Frankkl's Avatar
Frankkl Frankkl is offline
31" spare in stock location for 5$
Easy mod, cheap, if you cant fit that 31" spare in the back because of the speaker. Use a 10" bolt/hook a 5" long piece of plastic tube( inthis case a 4" pipe fitting) and a rubber hose to protect the rim from scraces.
The plastic pipe is to prevent the tire to touch the window because the tire will in in an angle.
not the best write up but some one might like it.
Old April 21st, 2007, 18:38
CHUGLYxj's Avatar
CHUGLYxj CHUGLYxj is offline
Re: 31" spare in stock location for 5$
nice idea!! If I had seen this a few months ago it would have saved me from the hobbled mess I made of mine, still works but was a pain to fit. Again very nice.
Old April 22nd, 2007, 16:19
mjma's Avatar
mjma mjma is offline
I have a 31" spare in the stock location. All I did was put the bolt through one of the holes for the lugs, instead of through the center. you just have to find the proper rotation angle for it to work.
Old April 23rd, 2007, 07:07
Pro Stock John's Avatar
Pro Stock John Pro Stock John is offline
Great ideas here, I'd like to get my spare off the roof rack.
31x10.50 in stock spare location cj11 Modified Tech Discussion 40 January 3rd, 2008 15:31
32" spare mounted in stock location Gojeep Modified Tech Discussion 22 April 28th, 2007 08:51
largest spare in OEM location MoparBoyy OEM Tech Discussion 1 February 1st, 2007 13:14
will a 31" spare tire fit in the stock location? Rambo OEM Tech Discussion 6 December 28th, 2005 13:54
Largest spare in factory location 97+ jkmhb Modified Tech Discussion 33 November 20th, 2005 20:26
