Old March 15th, 2007, 11:57
1989cherokee 1989cherokee is offline
Rear Hatch Inside Cover
Any one have to replace the little gizmos that hold the rear inside panel on the rear hatch. I bought the little round black push in pins from the dealer, but the mounts have broken off the panel itself? Any ideas?
Old March 15th, 2007, 12:15
mcnamaag's Avatar
mcnamaag mcnamaag is offline
Re: Rear Hatch Inside Cover
I used 6 self tapping screws, coated the threads with loctite and screwed them into the hatch. Other than that you will have to replace the cover.
Old March 15th, 2007, 12:16
truthchild's Avatar
truthchild truthchild is offline
I used some screws with the rubber with nuts in them that expand as they compress, got them at home depot worked for a bit but with washboard roads and bumps they seem to always work loose, so if anyone else has a better idea, Hint Hint
Drew
Old November 3rd, 2011, 16:26
Logans91XJ's Avatar
Logans91XJ Logans91XJ is offline
can you buy a new Rear Panel for the Liftgate?
Old November 3rd, 2011, 16:38
Voteban's Avatar
Voteban Voteban is offline
If you mean the trim panel, then yeah, I'd assume you can pick one up at the junkyard.
Old November 3rd, 2011, 18:53
cruiser54's Avatar
cruiser54 cruiser54 is offline
Factory fix for liftgate trim coming detached was 6 or 8 strategically placed trim screws with washers under them.
Old November 3rd, 2011, 20:37
Logans91XJ's Avatar
My problem is that the tabs on the trim are broken.. The junk yard is no real help since they are always busted up themselves.
Old November 3rd, 2011, 20:48
cruiser54's Avatar
Use screws.............
Old November 3rd, 2011, 20:56
cherokeefan_1's Avatar
cherokeefan_1 cherokeefan_1 is offline
3m makes a wonderful panel bonding adhesive that we use in the bodyshop for replacing certain body panels it will work great for glueing the buttons back to the cover.Not sure of the part number but its a black two part glue labeled as panel bonding adhesive.
Old November 3rd, 2011, 21:26
Logans91XJ's Avatar
sounds good I can try that
Old November 3rd, 2011, 21:27
ehall's Avatar
ehall ehall is offline
junkyard... but now that I have a bunch of other crap on the panel I have switched to using tie-down hardware so it is more secure, also so I can hang stuff from it
my '91 beater rebuild
Old November 3rd, 2011, 22:09
Logans91XJ's Avatar
I found it online at http://www.teamcherokee.com/
Old November 3rd, 2011, 22:12
Logans91XJ's Avatar
would like to see how you mounted that as I can tell I can see two screws one at each corner. Are you also using those Tie down points to also hold it in place? Where did you get those lights and how are they wired? Cost? I want to fix mine and also add the speaker bar from the newer cherokees.
Thanks
Old November 3rd, 2011, 22:38
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Like most here, I used self tapping screws. It doesn't take many to hold it on well enough, since the top has a lip to hold it on.
Old November 4th, 2011, 00:22
ehall's Avatar
The problem with screwing into the (older) hatch is that it's fiberglass and the threads will rip out unless you use an insert of some kind. For the tie-downs I used some of the spring-nuts/U-nuts like hold the bumper brackets in place.Some kind of nutsert would probably work best
The lights and speakers are bolted to the plastic, which is why I had to beef the way it was mounted
Interior lights activated by opening rear hatch cover . . . Don Becker OEM Tech Discussion 15 May 3rd, 2005 10:36
inside rear widow rack? TBCherokee OEM Tech Discussion 2 April 9th, 2005 23:06
Rear Hatch Interior Cover jeepownzme Colorado Chapter 10 April 9th, 2005 21:34
Rear Hatch Cover jeepownzme Colorado Chapter 0 March 9th, 2005 18:25
Better ways to attach the interior hatch cover jammerjamesharmon Modified Tech Discussion 3 January 30th, 2004 21:29
